Carb, air filter, governor spring & blower housing
FR is the lowest spec, then FS followed by FX
Fairly sure FF only come with 1" PTO
FS & FX are 1" or 1.125"
All of which should be of no real concern to most owner/operators.Carb, air filter, governor spring & blower housing
FS & FX are 1" or 1.125" PTO
Use to be..FX are now single barrel as well. Just so you know..FS air filter has screen mesh outside the filter media.
FS has single barrel carb, like the FR,
FX is a 2 barrel.. Just saying..
From Kawasaki, all engine models are 3 year warranty. I wish it was as you wrote.Carb, air filter, governor spring & blower housing
I have fitted FS to a couple of commercials and they are running fine but I upgraded the air filter to the FX dual element Donaldson type filter
The bolt patterns are the same but the FR is physically more compact to fit in tighter spaces
From memory the FS has blow out ports in the blower housing & the FR does not so you have to remove the blower housing to clean the fins
FR's have a single barrel carb, FS has a duel barrel carb
Blocks are the same cast iron liners and all of the guts are the same .
The FR's are a Hp or 2 lower but the torques are almost identical and it is the torque that does the work .
However the specs change all the time but basically it is window dressing so cheaper mowers can have a cheaper engine .
Down here the warranties were different , 2 years on FR, 3 years on FS & 4 years on FX
Basic engine is the same. If properly maintained they are about the same.What is the difference between a FR730V, and, a FS730V engine ? Is one more reliable than the other ?
Warranties vary from country to countryFrom Kawasaki, all engine models are 3 year warranty. I wish it was as you wrote.
Thanks, did not know of the change..Use to be..FX are now single barrel as well. Just so you know..
