Hi,
I'm Jerry from Indiana. I have an 11 yo Farris with an old style Kawasaki FH721V-CS27-R 25 ph engine. I'm a backyard wrencher but I'm better at fixing obviously broken engines than diagnosing what is partially broken. I've googled your forums and info I've found has gotten me a few steps closer but I would appreciate hearing peoples opinions on my problem.
I'm also looking for conformation of a potential factory defect regarding the pressed-in breather valve seat and advise on the next steps.
Know current state:
I believe the breather valve seat that is pressed into the block at the factory, was set at the incorrect height, to low, causing the breather valve to close on the "as cast" burred, aluminum surface around the hole in the block and not the inserted steel valve seat. See pictures. I'm including a drawing of the valve and valve seat insert from the service manual. I believe the drawing shows that the valve seat was pressed in from inside the block and shows that it protrudes slightly past the casting. (if accurate)
The witness marks on the valve from the burr and lack of witness marks from the valve seat are good clues that show the valve seat did not slip during use. I'm thinking that the valve worked well enough to do the job until "normal" engine wear caused crankcase pressures that the partially sealed valve could not handle. Note the non-centered burr mark circle on the back of the valve, it corresponds to the position of the installed valve.
I sent Kawasaki a message with a question about it from their site so I'm waiting for that..... In the mean time, I'm thinking about doing the following:
Thoughts?
Thanks,
Jerry from Indiana
Know current state:
- Personal, 1 yard (5+ acres) Farris ZTR bought new 11 years ago; Hour meter broken but I'd assume it's low for the age
- No engine maintenance done except change oil and blow off air filter, well and new plugs a few times...
- I neglected to change the oil in ~2 years
- Oil; level OK but dark, still oily, not broken down completely
- Road hard, put away wet several times
- Then at cold start up, smoke came from exhaust then it died
- Found breather tube was pumping out oil into intake plenum before carb (big clue!)
- From googling your forum and experience I'm reading that is related to excess crankcase pressure
- Bad rings? Valve guides or seals? Clogged breather drain or breather valve issue? Clogged air filter, ?? idk?
- Compression check=90psi in both cylinders (I know, I should have changed the oil more often but maybe not the main issue...)
- Leakdown at TDC; 30% and 32% but this was a HF automotive leak down tester with .040 in. orifice so maybe not too bad since they are similar numbers?
- Inspection of valve seals showed no issues
- Harbor Freight inspection camera down the spark plug holes showed no holes or bad scratches in cylinder walls
- Did tear down to get into breather under flywheel
- Inside I found dirt (sluge?), oil saturated breather filter and issue with breather valve (reed valve) seat
- Remove burr from casting for a better seating surface for the breather valve.
- New breather valve, breather filter element, canister air filters, valve cover gaskets, upgraded no leak breather cover, plugs, oil filter, oil maybe a little heavier SAE30?
- Put it back together and monitor crankcase pressure with a fuel/vacuum gauge
- If it works, use it for the rest of the season then do a freshen up rebuild with new rings and a hone job this winter. I can better inspect the valve seat for full insertion when the engine is tore down.
Thoughts?
Thanks,
Jerry from Indiana
