Correct - we need to be specific here, because my FH series is an older one.
I typically try to be very clear in my questions and answers; hence why I listed the specific models of the engine data I looked up on the Kawpower website.
So I also found this same disucssion on another forum over at
www.lawnsite.com and the same topic ended up with the same conversation, although it took them about 10 pages to come to the conclusions that it only took me an hour to discover. You can see the conversation here, but just focus on the photos on page 9; there are a few photos:
a) photo of the part used including the oil cooler set and throttle shaft
b) installed oil cooler
c) another pic of oil cooler
d) view of the 19hp shaft sitting next to the 25hp shaft (this is the most credible evidence and makes it so very simple to understand)
You can see the info and photos here:
http://www.lawnsite.com/showthread.php?t=317558&page=9
Now I am constraining my comments to my older series of FH engines; those that are all at the top of the displacement list from 601-721 series.
The ONLY thing (and I truly mean only thing) that separeates those in HP ratings is the little throttle butterfly shaft, which limits the travel of the shaft in its rotation.
Kawasaki has made a bazillion different variants of many engines, but when comparing and contrasting info within the same bloodline, this is a true statement.
You can "up-power" your FH engine (FH601V - FH721V) by simply removing that restriction. You have two choices:
1) buy the shaft for the HP you want (the 25hp shaft is 16041A-7025 is is currently about $40 give or take a bit) and install it after removing the carb, govenor, etc and put it all back together
2) get out a dremmel and cut off the offending metal on the shaft tab (I did this; took me about 60 seconds ....)
I cut off the matieral using the photo link from above as a guide. I printed off the photo (copy/paste caputred and put into Word) and then used sciscors to overlay the "new" part on the "old" part, so I could scribe a line that would represent the material to remove. If you refer to that photor link above, what I did was essentially cut off the portion of metal that has the "A" stamped upside down in the picture, and made the cut at an angle that replicates the 25hp shaft on the right.
Viola! 25hp out of my 19hp Kaw engine. The engine will now open up the butterfly shaft MUCH further, allowing for a much larger air/fuel mix under heavy loads.
Under light lights, it works just the same as any other engine would. The govenor controls the throttle shaft.
Because I didn't take anything apart, and my mower ran fine previous to this little experiment, I had no issues in having to "return" the idle speeds or govenor setting. I highly recommend that anyone doing this actually take the short cut (pun intended) and just cut off the metal material. Doing this is quicker, and there is no need to mess around with your carb and govenor settings.
I would remind those who try this to seriously consider adding the oil cooler as well. If you expect that high-loads would be rare for long periods, you can probably get away without it. But it you intend to use the new-found power for sustained periods, I really suggest you add the oil cooler; it is very inexpensive - only cost me about $25 when I added it a few years ago. (You'll need the heat sink cooler, the o-ring and the threaded extension). You can find those part numbers on the Kawpower website under the FH721 (25hp) engine parts listing. You can see my thread about this upgrade here:
http://www.lawnmowerforum.com/scag-forum/8933-kawasaki-oil-cooler-upgrade.html
Yes - it truly is that simple to achive a 30% power gain.
