Bulldogparts
- Jun 2, 2018
- 1
- 8
I have adjusted the valves, adjusted the governor, and thoroughly cleaned all linkage. And rebuilt the carb. It will not run unless 1/2 to full throttle, and is surging constantly. I cannot set the idles while it’s running like this. Have I missed something?
The original problem was once hot, it would act as if it was starving for fuel under a load, and was surging. I could choke it, and it would pick up and run a few more feet, then try to cut off again.
Thanks............and Hello from Georgia!!
