Yes I did , 200 something to me .  Latest , pulled bottom cover off , pushrods out , checked cam timing right on both dots , Measured the cam lobes all the same within  a fraction of a mm , anyone know what they should be exactly ? . measured the lifter stools all exactly the same . Pushrods are all the same length. Motor has 125 psi both holes . Pulled the intake to be sure I didn t leave a rag in it as it was apart waiting for gaskets for quite a while , nothing there right to the valves both sides . Checked the governor balls , all correct and in place . What the heck am I missing .
