Thanks for the info. Went there, type the model, serial number unknown, didn't go thru, gave up. Called the lawn mower shop where I purchase the starter.
Out of 3 wires connected to started, I had only 1 correct. I have to place the ground wire behind the starter, and mount it on the frame. Then find the wire from the starter and place it on the other side of the starter solenoid. I ask him about the spark, and he said I had it wired incorrectly, and if I wire like he says there should no spark.
Thanks,
Kathryn
Great Green thumb with gardens, allergic to wasps, and this is where my problem started.
I have a Huskee 16.5 OHV Briggs and Stratton
313777-0112-E1 00337ZE
Model- Type Code All of this is located on top of the engine, where the fuel filters are at.
TSC-44-9761-5----MTD 13AN673G131 All of this is located under the seat.
Replaced a new Starter Solenoid: Connected the red wire coming from the battery, which also has a small red wire connected to it on the left side of the solenoid.
Connected the black wire coming from the battery, which also has a small green connected to it, and connected it to the right side of the solenoid.
? There is a black protected cable with a solid red cable with a post connector, does this wire also go to the red battery cable? I was placing the negative terminal bolt on the battery, when a spark flash, even before I placed the nut on the bolt. I am moving the negative wire from touching the housing for the solenoid; after reading an article under installing a car battery.
Thank you,
Kathryn
Kathryn , my sincere apology, sorry for misleading you on the manual, I've put up the link to the manuals page for your model, the wiring diagrams are in the ..............PARTS GUIDE 00, Form # 770-10006C starting at Pg. 36 , you'll have to enlarge your view or maximize your screen to read it properly, ... again ... SORRY for the mistake, ......... Boobala ....:ashamed:
http://www.mtdproducts.com/equipmen...Code=03&modelNumber=13an673g131&serialNumber=
Hello Boobala,
I got the mower running, used a couple of times, and this morning it wont start. I have the choke pull out all of the way, the throttle position half way, the brake on, in neutral, and the blades unengaged. Is there a switch somewhere that is causing the mower not to start. Thanks, Kathryn
Is it clicking?
Turning over and over(cranking), but not starting?
No noise whatsoever?
Did the battery go dead? possibly a wire still wrong.
Is it clicking?
Either it is not getting any fuel or not getting any spark.
No fuel will be the cut off solenoid under the carb.
Hold it with your fingers and it should click when you turn the mower on & off, no need to crank.
If it s a no spark situation tht will most likely be because one of the safety switches is not working.
You will need some tools to test these, a minimum will be a test lamp.
Kathryn in Texas...
I was thinking about you new problem along with reading all the responses.
It is a fuel, firing, or air problem...that is what all the responses are saying.
1) Are you out of gas? it happens...
2)Did the plug foul? I ran out of gas and it backfired. I pulled the plug because it would not start...then I realized I had run out of gas.
3) Is the air filter dirty? not enough air flow to pull fuel...try to start without air filter and/or put a little gas in the breather tube and start it.
Start with the simplest first and narrow it down to an air, fuel, or firing problem.
Then, we can work our way through it.
These may be of some help .......... CLICK on each link below...... Boobala
http://bsintek.basco.com/BriggsDocumentDisplay/Z6llAEVJ1DajI.pdf
http://bsintek.basco.com/BriggsDocumentDisplay/flmmwKX-nfBhU7y.pdf
http://outdoorpowerinfo.com/repairs/briggs_walbro_lmt_carb.asp
Did you see these files , they are links to information on your machine .......... :mur:
