K341 Engine parts breakdown
sjptak
I guess I'm no good at searching. :( I have a Walker M16AQS with a K341spec 711562. I need some engine parts as this has a busted rod and more. Does anyone know where I can find an online part breakdown and maybe someplace that I can get parts?
Maybe I'm trying to fix a boat anchor?
Scrubcadet10
Moderator
Staff member
here's all the K341's, but none of them match the spec number. and i cant find that spec number in any lists.
Actually you are as depending if you need a piston or not as it is NLA. The old style rod is NLA and the new style is well over $100 alone.
I can't attach the IPL due file size restriction.
Doesn't appear that the 711562 is a valid spec number for a K341 but it is a valid spec for a M16 on a walker mower. And from the M16AQS I would say that is the engine not the K341
It is a valid spec per Kohler Plus website. It also cover the IPL for the 711500-711587 specs. It is listed as a M16-711562 but I check one of the other Specs within this range under the K341 and PN part numbers are the same as the ones used in the M16 of the same spec.
