I have a Troy-Bilt tiller with an 8 hp Kohler K181ST-301006. It is electric start. It has point and condenser. It won't start, getting fuel but no spark. I used an inline spark tester and I'm getting nothing. I tested the points and they were not making contact. I cleaned the points and gapped them and they tested out great, good contact. I rechecked with the inline spark tested but still nothing. I used a small lighted current tester and connected it to the spark plug cap. When I turned the engine over it was lighting up. That led me to believe the coil is sending a spark, just an extremely weak spark, not enough to light up the inline spark tester. Would this indicate a problem with the coil or a problem with the condenser? I was inclined to go ahead and order a condenser since that was cheap and easy to swap.
Another question about this. There were three wires connecting to the condenser, one wire going to the points, one wire going to the ignition switch and one wire going to the grounding tab on the linkage panel that continues on from there to go behind the shroud to where I am assuming it connects to the stator. In the picture you can see the three different wires, I have them disconnected. I tested the connections, with all three wires connected to the condenser, the condenser showed to be grounded. I disconnected the three wires and the condenser tab was not grounded. Each one of the three wires were tested separately and showed they all were grounded. The wire going to the stator was grounded even after I disconnected it from the ground tab on the linkage panel. Should those three wires be grounded? Doesn't seem to me that they should.
I was going to remove the flywheel just to check the shaft key but I wasn't able to remove the flywheel so I gave up on it. Not a big deal except I was not able to inspect the coil or magnets.
