Just wanna brag a little
I have a concrete floor in my space, & at the work bench I have rubber backed carpet. Really helps on my feet, standing there..
And use cardboard to throw down so I can slider under whatever.. My creeper is too tall.
I guess I am really lucky since we have a Heftee 2000 lift and it really makes it a lot easier to work on mowers. Some genius before I started working there made a rolling work bench that you slide under the mower after you raise the lift and drop the deck right down on it. Sure beats rolling around on the floor. We could use a bigger one now since we are getting bigger zero turn mowers 72 and 74 inch cuts. These are really too wide for the lift but I can up them on and raise them up enough to put a jack that attaches to the lift arms and put under the frame on the outboard side and strap the other side to the main lift frame to make it safe to work on.
