Just can't get going
prosen
Hello, I have had the bad boy for several years and it has been great, but suddenly it does not want to start going. I fool around with the control for a while and it suddenly engages and all is fine. This has happened the last few times I have tried to get started. Any suggestions?
gainestruk
We need more info, won't move ? Mower deck won't start ? Also model number of machine will help.
Hardluck
You need to check the ground wire. Have you replaced the battery. There is a second (small) ground wire that must be cleaned an tight for the safety features to work properly.
HarmonySeeker
I am a bad boy, as well. Sometimes, I just can't get going.
