Engine Jonsered ride on advice
gerard35
hi ive a Jonsered ride on its 1 year old, when i turn the engine on its trying to start but not, ive changed the solendide and the battery if of charge, the starter and solenoid and battery gets hot when i try to start a few times,
can someone help me please
I am guessing that what you mean is that when you turn the key to the "start" position is that the engine doesn't spin? First take off the plugs, and try to turn the
flywheel by hand and see if it will rotate, also check your oil level, and post your engine's model numbers.
yes i took spark plug out, the flywheel turns ok, yes oil level is grand
bands Model 31E777-2439-B1438586
