JCAllison
- Mar 21, 2012
- 5
- 59
The steering gear and/or plate is probably worn. There are no adjustments. Look below the fuel tank at the steering shaft and you should be able to see the gear. It may be above or below the chassis. Look to see if the teeth are worn there is a lot of play in the shaft. It may also be a worn bearing at the bottom of the shaft.
Hey Rivets,
Alright. Will do that the next time Crafty is out from under her tarp. It seems strange to me that the steering is GREAT when turning Left, but isn't good at all when turning right. Will let you know what I find.
JC
