The mower has fuel in the carburetor bowl, there is spark to the plugs, the engine cranks fine but it will not start. The fuel pump is working the carburetor solenoid is working it just will not start. It was running fine and then starting cutting out and after parking would not start. I suspect some safety feature but with no manual don't know what to look for. Oh, I only see one inline fuse and it's ok.
There are very comprehensive technical manuals available for every thing John deer ever made, including the ride ones.
They are by far the best mower manuals ever printed.
They assume the owner has never seen a ride on before so tell you the theory about how each part works , exactly where the part is hidden on the mower then go into a step by step detailed account of how to diagnose your mowers problem.
Not just a flow chart, proper instructions, push this in , pull that out sit on seat turn the switch to ??
Down side is they are around $ 40 as a digital download and closer to $ 100 as a paper copy.
he parts diagrams are also available on line , for free but you can only print 1 page at a time
And according to the Z930M diagram your wiring has a fuse, 2 x relay & diode.
There is also an engine control module fitted to some
Back in post 13 I asked you to confirm that you can get a fuel supply from the tank.
I am yet to see an answer to this.
I also asked for the same thing in an earlier reply.
In order for fuel to get out of the tank, air has to get in (or the tank implodes )
ZTRS kick up an enormous amount of dust and having the engine AND FUEL TANK behind the deck are prone to injesting lot of dust and that is before all of the other detritus that seems to be attracted to the big filling holes.
Good chance the outlet of the fuel tank is plugged which is why, way way back I asked you to blow back down the fuel line, this will temporarly dislodge a plug in the fuel line.
I also asked you to see if you can suck fuel through the fuel line which we are yet to see an answer to.
Fuel in a see through filter means nothing unless you can see it flowing.
One set of safety switches prevents the engine from cranking and another set prevents the engine from sparking.
You said your engine did both so there fore the safetys are not nor never were a problem which is why they were never mentioned.
Electrical system break down
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
I have done the best I can for you
Good luck & good bye
