John Deere Z425
Dtodd84
Hello, I recently noticed my ground cable for the battery came loose along with a wire coming from the engine area with an identical terminal end as the battery ground. It appears they were grounded together somewhere but I can not find the correct location.
While messing with them I was able to get the mower to start if they were touching near the frame. But now it won't start. Just the solenoid clicks.
My question is where do these 2 wires get bolted to and why won't the mover turn over now. The battery is good and I tried shorting the solenoid to see if it'd start.
Thanks
Dave
