John Deere Z425 runs PTO and Hour meter not working
tcs39759
  • / John Deere Z425 runs PTO and Hour meter not working
Z425 mower , PTO Clutch Ohms correct and continuity on wiring checked. Stator has correct voltage out and so does voltage regualtor. The PTO switch checks out, and replaced just in case. Could relay be bad even though the mower starts up fine? At a loss.
tcs39759
oh also "might" be relevant, carb solenoid is disconnected.
sgkent
can you post your wiring diagram so we can look at it?
tcs39759
I believe this is correct
  • 425_Old_PTO_Schematic.pdf
tcs39759
