TracyStiles
- Jan 23, 2016
- 1
- 1
Hi everyone, I'm new to the group. I'm working on a friends mower and I have run into a problem. I'm replacing the bracket that goes to both, R & L transmissions. It broke causing the wheels to angle in. I also have to replace the plate the engine bolts to, it broke where the transmission is mounted to it. I'm trying to remove the electric clutch and the bolt is frozen in place. Is the bolt that holds the electric clutch on, reverse thread? Also what size is the washer you put the wrench on to keep the crank from turning? I'm gonna have to buy a wrench to get it off. Thank you in advance for any help.
