mitch_houser
- Oct 8, 2012
- 9
Another update after watching a youtube video on how to check a relay the right way I did a test on my friends and it failed looked up the relay 19.99 afte watching the video and seeing that all relays are basically the same I found one advance auto 5.99 same amp same pattern same numbers in pattern plugged it in and no more problems everything works like it should .I just need to know the parts diagram I was looking at dosnt show what the choke linkage is hooked up too I know when you push the choke position up it closes the flap I see it moving I know where one the flap to connect rod and the slit you put it in just cant find a spring listing to hook it up to the choke connection.Ive got the choke lever installed it works it pushes it close when I move the lever but after engine starts I move it down and valve stays closed is the lever bent out too big in the slit making it bind and the pull on intake will open it automatic?????????
