mitch_houser
- Oct 8, 2012
- 2
- 9
Mowing along everything is fine mower shuts off .Cranks back up but when you take the parking brake off or the blade PTO engine shuts off dragged back to shop let it set overnight went out checked fuses ok checked fuel supply ok looked for disconnected wires to safety solinoids ok .tried to crank and smoke billows from exhaust cut it off checked oil its now high smelled oil and the high was gas in it.My mystery question is can the seat and needle I know can cause gas entering in crankcase but is there a sensor in crankcase that would tell it too much oil and shut it off before it started smoking are they related or just a fluke?
B&S 18.5 hp----- Model number 31P7 77 0146 G1
