Hey Will, thanks for stopping by. I've been cutting this morning for a few hours and scratching my head the whole time. Right off the bat after I start cutting, it died. Kept doing that frequently for awhile. Sometimes would start back up and sometimes not ( right away). I started shutting off the PTO "immediately" when it would die and it would keep running. For awhile I would just hold it up while cutting. I was able to cut and when it started to die I would just flip the PTO switch off and on sometimes and it would keep running. If not it usually started right back up. First time I've noticed that. Anyway, I thought your suggestion sounded legit to me so I'll go out now and see what you're talking about. I'll let you know the results. Thanks.I just read all the posts. Thankyou for the detailed description of your issue! Easiest way to differentiate between a fuel issue and electrical issue is to hit the choke when the engine starts to die. If it makes a difference, your issue is fuel related. If it doesnt make a difference, it is not fuel related. That being said, the one part not mentioned above is the interlock control module located under the dash. You can identify it by following the wires under the dash. It is held in place by a 10mm head screw. This is the 'brain unit' for the safety system. It has a time delay built into it. It can fail and randomly cut the spark to the coils. The way to properly test it is to disconnect the black wire at the engine. Mow your grass. If the engine never shuts off, the interlock module is your problem. Note: with the black kill wire disconnected, when you turn your key off, the engine will continue to run for a few seconds until the fuel shutoff solenoid on the carb kills the fuel. Use caution. I have replaced many of these modules and Deere has subbed them many times. Good luck!
