John Deere tractor troubles
ktay
Hello Friends,
I have a JD X320 with less than 200 hours on it. I used it yesterday to do some snow blowing and it sounded like it wasn't running at full power. I turned it off and restarted it and it sounded better and I used it for an hour or so with no problem.
Today it won't start at all. Gives a whining noise but won't turn over. The lights come on fine so I think probably isn't the battery. I don't think it's a safety switch because when I tried to start it with the PTO on it didn't do anything, not even the whining.
I did notice that the brake won't lock on. I can push down the brake all the way, no problem, but I can't lock it there. It has a plastic tab that you are supposed to pull up while stepping on the brake. I thought the tab might be frozen in place since I've had that happen to the PTO, but that's not it (I used a hairdrier to melt off the ice and it still won't move).
I'm a "wiggle the wires and hope" sort of repair person. Is there anything more productive that I can try? Perhaps kicking would work.
Thanks for any help.
mullins87
How cold is it where the tractor is stored? Sounds like the starter is not engaging the ring gear on the flywheel. I have an old Snapper garden tractor that will do that when it's cold. The starter motor will just spin freely when you try to start it.
Willing to bet that the starter bendix is either frozen to the shaft, not allowing it to engage the ring gear or starter gear is broken. Which engine model and serial numbers and I'll tell you if you can fix it or take it to the shop.
ktay
It hasn't been that cold (yet). It's in the 20's today. Tomorrow supposed to get closer to zero.
The engine is a Kawasaki "MakeiTorque Power system" Model # FH661V.
Serial # FH 661V-CS04-R.
Thanks for your suggestions.
ktay
Thanks for your help. I'll don my coveralls tomorrow and dig in.
ktay
I started with the easiest attempt. I went out with my trusty hairdrier and aimed for the starter. After 5 minutes or so it started right up. Good. It was too cold to be taking things apart.
Thanks for the help.
I would take a can of synthetic spray oil and give the gear a good bath. White lithium spray grease would also work. Click the starter over a few times to make sure you get things coated good.
Carscw
Very good advice. I am going to do this to all my starters today.
Thank you
Sent from my iPhone using LMF
I should say that there is one draw back to doing this, (giving gears a bath) if you a in a dusty area, the lube will attract dust and could shorten gear life. I have used spray graphite in dusty/dirty conditions.
