Hello everyone.
My battery is good. Tested at 12.5 volts, starts fine if starter is jumped with battery.
I can jump start the starter with jumper cables and it fires right up and runs fine.
When I turn the key to start: nothing
How do I test if my key switch is bad?
I tried taking off the connector to the key switch, and jumping the ground and starter wires: nothing
Taking connector off and jumping from the connector ground and the starter wire AFTER the solenoid (or coil? under the gear shift, unsure of the name): turns over fine.
Is it absolutely my coil/solenoid whatever that mess of wires is under the gear lever?
I just picked this mower up for free, so I am not too familiar with it. If the brake is ON, will it start WITHOUT someone sitting on it? (I'm trying to fix this myself and don't have an extra person with me)
Will simply unplugging the seat switch make it to where I can start it? (Once again, I understand the safety issue, I just only have so many hands by myself)
Thank you!
Thank you!
