John Deere speed
Look at the blowup on the thread!!!!
Bolt # 3 And pulley #31, that is obviously an adjustment point.
That should do the trick, if not, someone may have put on a smaller idler pulley, but that is the adjustment point.
Thanks Fish I got out there this morning laying under the mower and finally, I saw it. Just what you said. I replaced the belt and probably didn't even need it. I could have tried adjusting that on the old one, might have fixed it right there. Thanks for the reply, this site is good help.
Most brands do not have any way to adjust, so you were lucky there.
Also why I like having the tractor and engine's model/spec numbers, to look at the blowups, the fix could be right there....
