Hello All,
Please go easy on me as I am a total novice when it comes to lawn mowers and repairs in general. Anyway, I inheirited a JD LX188 from my new homes previous owner. He warned me the starter was going on it and you had to hit it to get it going. I was able to do this all last summer and one time this spring with no issue. However, the last time I hit it all the lights stopped coming up and it would not turn over, I hit it again and they would sort of come on and it would crank once then back to nothing.
Since I knew the starter was bad, I went out and got a new one. Had no trouble installing the new starter and carefully put everything back to the way it was before, I even replaced the positive battery cable with a new one since it showed a lot of wear at the connectors. I then tried to crank it up and I got nothing, no dash lights no clicking etc... All the connections seem correct, battery has power, Saftey stuff was all engaged, so now I am here.
I plan to get a multi meter but need some details on what to check. Also, is there anything I could have knocked loose that may have caused this. Any and all help would be most appreciated!
Cheers
Briz
Cheers
Briz
