John Deere LX188 Drive Belt Replacement
Schnidly1958
Dear Forum,
Can someone please walk me through replacing the transmission drive belt on a 1996 LX188. My transmission was making a ticking noise as it was idling so I did some inspecting and found a piece of the drive belt for the transmission hydrostatic drive missing and most of the belt cracked and split. This is the original belt. Looks to me that the electric clutch has to be dropped to get the belt off there. Any help and a complete description on how to remove and replace this belt would be much appreciated. You can email me the instructions to rfschmid@wi.rr.com. HELP PLEASE!
sammytall
:confused2:did the question get an answer? I also need to know!
OK Sammy, easy job in a difficult position to work in.
So I drain the fuel tank then remove the battery.
This allows the mower to be lifted from the front & sat on its bum so you can see everything and not eat grass.
This is what you have underneath, engine towards the bottom of the page.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Remove the tensioning spring ( 7 ) and idler pulleys ( 16 & 11 ).
these pulleys will most likely require replacement so you may as well do it now.
Being this is a Deere, the bolts are captive coach bolts but you might need to put your finger on the head to stop it slipping out of the square hole.
Check the two bushes ( 17 ) and again, I replace them purely because it is easy to do while everything is apart and they will be worn.
Just make sure you remove the pulleys first before you take the pivot bolt or you will need 5 hands to hold everything.
Loosen the belt guard ( 3 ) you can remove it if you like.
To get the belt off the tranny slip it between 2 blades then rotate the pulley.
The belt will just about fall off now.
While it is off, give the fan on the transmission a good check out, the splines get worn down and if they strip then the fan will not be able to cool properly.
Installation is as they all say the reverse and it will be a lot easier to do the fan pulley first.
Double check the belt is in all of the pulleys properly before you replace the spring.
Allow a couple of hours this being the first time you have done it.
mjb8fj
to get that tension spring off, try using some cord or string (I use 550 cord), all you need is about a foot. Slip an end thru the end of the spring, pull until you can maneuver the spring off its location. Then when you put the spring back on, stretch it and maneuver it in place, release, then pull the cord thru. Also while you are replacing that belt, check those transmission idler pulleys- that's the best time to replace them. Yes they have sealed bearings in them, but they will go bad at some point, which might be the ticking noise you heard? If you need help with anything email me here
