I had an LTR180 too & never had any drama with it for c. 800hrs+ - until my son seized the motor, by running it without oil after he forgot to refill post oil draining/"change" - I reckon it would have lasted to least 2000-2500hrs before any major component change out/repair & the tranny is still giving great service behind a 25hp motor in a much abused home built self propelled tipper/spray rig/water pump.
As for your belt consumption, labour & pricing it seems way over the top, sounds to me like:-
1. The dealer is charging a premium professional rate for a sub standard service which has failed to rectify a unique preexisting condtion on you mower (like maladjusted deck or pulley alignment)
or
2. You may be cutting extremely tall grass at too low a setting with a big deck & the torque of the motor is chewing the belts out rather than stalling
My advice would be to invest in a technical workshop manual & do the work yourself (no maintenance on a rider is by any stretch of the imagination hard & given your dealer experience to date at best you'll fix it, at worst your mower will be no worse off) what you'll save in downtime, transporting the machine to the dealer, dealer labour costs & exhorbitant parts pricing you can put towards a new rider if its required .
In GT's & conventional riders JD's are the weapon of choice in my area & all of us do our own maintenance repairs as the dealers are too distant- though interesting none of us choose to run JD tractors on our farms so we can't be considered "green" biased . As for zero turns the jury is still out on the best residential brands & personnally I wouldn't considered any ZT below a commercial grade machine.
As a comparative, I purchased s/h a LT155 38" cut with c.150hours on the clock 4 years ago & it now has just over 1050hrs so it gets used quite a bit !!! Predominately on cutting 3acres of lawn (my lawn = tamed naturally paddock grass & cut dry, wet or frosty ) & occasionally hauling a lightly loaded JD trailer with filled with mulch, or plants & garden tools) - after these hours no rust anywhere, engine has never been touched (apart from prescribed valve adjustment) & runs as new, the tuff torque tranny runs as new, belts & spindles are original, in fact no component has needed to be replaced through wear - all in what can best be described as a mostly harsh hot dusty & highly mineralised salty environment - though I am fairly meticulous in maintenance ( refer my post on best JD mower for details)
or
