Afrowookie
- Jun 23, 2016
- 1
- 6
Hi all,
I just got a John Deere LT166 from a friend who says it doesn't start and just gave it to me. It has a B&S Vanguard V-Twin 303777. I have messed around with it for a while now and got it to the point where gas is getting to the carb bowl and have flooded the engine once already but still not starting. It was sputtering but not actually starting and stay running. Since then I have drained the oil, flushed it and replaced with new oil. I have partially taken the carb apart and sprayed it with carb cleaner, removed the main jet and float needle, soaked them in carb cleaner over night. Still nothing. So I am down to either a carb overhaul or a new carb. On one site the carb overhaul kit alone was $125 for a bunch of washers, gaskets and hardware, that's crazy. On the same site had a carb for sale but that was over $200. The carb no longer is available now, and every other site I go to who used to carry it either says "Discontinued" or "No Longer Available". But I still see Vanguard engines for sale on other sites. So does this mean anyone who owns one of these engines are now screwed if they have a carb problem? Can you use an alternative carb by another brand?
