Hello all,
I've got a John Deere LT160d 42" lawn mower and I'm having the WORST trouble getting a new deck belt installed. I mean... this has been rough! It's just too freakin tight!
When you guys replace your deck belt, do you disconnect the deck from the mower or do you leave it hooked up while you put the new belt on all the pulleys?
I ask because with the deck connected I could NOT get the new belt on all the pulleys- no matter which one I tried last. I tried articulating all the levers and pedals to make more room. When I disconnected the deck from the mower, I was able to slide it forward enough to hook through all the pulleys even the one coming off the engine- but then it was too tight to be able to hook the deck back up!
Please help!
Please help!
