John Deere Lt155 Sluggish Hydrostatic Drive
JBASport
I have a John Deere Lt155 Ride on Mower which struggles on the slightest incline. I assume it is the hydrostatic drive that is the culprit. Is there a way to check? Is it an relatively easy job to service and if so can I buy a service kit? Many thanks, Terry
Park on a reasonable hill
Mower in neutral , brake off give it a push
A good hydro will be hard to push and stop moving when you stop pushing
A totally stuffed one will race away under it's own force the second you let the brake off .
I have a tilting trailer that I collect mowers on and that is my test .
There are a lot of other things that can cause your symptoms from excessively worn belt, either pulley worn ,stripped spline on the gearbox pulley .
JBASport
JBASport
Thanks for that, I will give that a try. Terry
