Export thread
John Deere LT150 Not starting
#1
T
Trooper
I have a LT 150 with a kohler motor that appears to be flooding out. I have outstanding spark. The motor backfires thru the carb and out the muffler. I'm thinking that the needle valve in the carb float is stuck and letting too much gas in. The plug is wet when I check it. I have checked the flywheel and the key is Ok. Any thoughts?
#2
Glyn Robinson
Glyn Robinson
you're possibly spot on with the needle diagnosis.
#3
T
Trooper
Thanks. I'll get on Saturday.
