Engine John Deere LT150 Not starting
Trooper
I have a LT 150 with a kohler motor that appears to be flooding out. I have outstanding spark. The motor backfires thru the carb and out the muffler. I'm thinking that the needle valve in the carb float is stuck and letting too much gas in. The plug is wet when I check it. I have checked the flywheel and the key is Ok. Any thoughts?
