JimmyTheFingers
Hello, I've got an LT 166 mower that starts to get pto belt slippage when i get into thicker/taller grass. It should definitely be able to handle it though just wondering if there is a way I can tighten the pto belt up. If I push through too thick of grass I can hear the blades slow down and start to get whiffs of the belt starting to smoke, If I lift the deck the blades take off again. Can I snug it up by adjusting something, or do I need a new spring or something under there?
Thanks
Thanks
