John Deere Lawn Tractor 285 Water pump replacement
nodeere
I have purchased a new Kawasaki water pump for the John Deere 285 17 hp lawn tractor. I am asking for advise because I have been able to drop the first two sections of the pump but the bolts are preventing the removal. I am guessing the top section of the housing needs to be removed. The pump I purchased came with two gaskets. I assume a third gasket is needed when the top portion is removed. Thank you in advance.
