Thank you gentlemen for all responding, I will bring you up to speed
Big snip
Now the mower will not fire at all, and I am seeing some raw gas coming out of the exhaust pipe, the battery is on a currently on a charger, since I ran it down
The mower has a briggs and straton engine if that helps
The spark plug is new, and the air cleaner seems to be in good shape
please advise, if you can see what I am missing or if I created a new problem without knowing I did something wrong
Regards Al
Is this liquid gas or vapour ?
Liquids do not burn, only gasses burn so if liquid is dripping out out of the muffler then the float is stuck and it is flooding.
Pull the carb off connect the fule lines to it and crank the engine.
no fuel should come out of the carb.
If you have a vacuum that blows, hold it to the intake of the carb and look at what comes out, should be a fine mist of fuel .
Note if all is well this will be a very flamiable fuel mist , so no sparks, cigarettes, naked flames etc.
If all checks out OK, try a fresh plug.
modern fuel which is nothing like petrol is highly conductive at cylinder pressures so can short out a plug in no time flat.
If fresh plug makes no difference check the flywheel.
There should be a 1/2 square slot in it and another in the shaft.
If the key is intact they should line up to form a square.
crank the motor a few times and see if it changes
