john deere la 175 steering problem
scrimshaw
My front wheels point in different directions. If I straighten one the other points at a 45 degree angle.:confused2:
KennyV
WELCOME to these Forums...
You have either something Bent or wore out...
Take a close look at the steering gear & linkage, check the draglink that connects the left & right wheel...
also check for worn bushings... :smile:KennyV
jabone
Did you solve your problem, I have the same thing on the same model. I checked all what was mentioned and found nothing.:confused2:
