- May 28, 2014
- 938
Sounds like something is loose.
The pto runs off of the voltage regulator.
You should be able to reach while sitting in the seat and leaning over.
With the blades on wiggle the wires on it.
Also move the pto switch side to side.
It's going to be a bad wire or a bad connection or ground.
Does the mower have a amp meter on it?
Could be the charging system is not keeping the battery charged to full charge. The pto clutch loads up the battery
