john deere l130 NO CRANK NO START
Danarobertson
Y problem is I start the mower fine, mow the lawn park it and shut it off. When I go to restart the mower, nothing. I find the 20 amp fuse blown.
Divad h
John Deere Service Advisor 4.0 CCE (Commercial and Consumer Equipment)dealer technical assistance, diagnostics, connection readings, calibrations, interactive tests, specification, tools, assemble and disassemble presented all models John Deere Construction Equipment and some models Hitachi, Euclid, Bell and Timberjack.
Mantis Toebogon
One more test. Turn the key switch to run and jump the solenoid as you said you did in your first post. You should be able to start your unit. If the unit starts, your problem is a bad solenoid, which will need to be replaced.
What happens if it doesn't start? My L130 starter just spins but won't even turn the motor.
Starter bendix is shot. Need to either replace the bendix or starter. That is if you know you have a fully charged battery.
