Hello,
I am new to this forum and kind of green when it comes to repairing mowers. I have an L130. My PTO switch just went out again after having only gotten a couple hours use out of it. It was brand new and I replaced it only after I checked the PTO which read 3.9 with an ohm meter. With the switch on the clutch does click (not all that loudly) so I assume the electro magnet is working right but I cant figure out why my new switch stopped working so fast. Could it be the clutch is going bad and causing the switch to burn up? The mower itself does turn on and off properly and the safety switch does seem to work when you get off the seat. Prior to this debacle the main fuse did burn out and I replaced it. Could both of these be a sign of one electrical issue? Thanks,
Vteezee :confused2:
Vteezee :confused2:
