Well.... got the bowl off, looks like there might have been some water in the gas that was in the bowl.
Squirted carb cleaner in there and it comes out the bottom. BUT when I took the bowl off there were 2 little things in there. Not sure
what they are called, real little brass things and each has an O ring. According to the JD parts catalog there are 2 jets,
guess that's what they are but don't know where they came from. There is a main jet and a high altitude jet.
I did not take the solenoid off, it is still attached. Guess I will try to put it back together and see what happens.
Cross your fingers!!
