John Deere L120 Won't stay running
Hi.
I have a John Deere L120. Two weeks ago it started right up for the first time of the season but had almost no gas and ran out after about 10 minutes.
Now I can get it started by putting starter fluid in the air intake but it will only run for a few seconds and then dies. I had put the last bit of gas in it I had and decided it might not be good so
I drained it and put a new fuel filter on and filled it with new gas with stabilizer in it. It starts with starter fluid but won't stay running. Please help!!
Mikel1
Do you have good fuel flow from fuel pump to carb?
Hi.
I took the fuel line off past the fuel pump and plenty of gas comes out so I was thinking it's not the pump?
Mikel1
If that is good then do you hear a click from the fuel solenoid when you turn the key on? If that is good then carb needs cleaning, float valve needle may be stuck.
When I try to start it all I hear is the engine trying to start. Do I just need to turn the key to the on position to hear the clicking?
Mikel1
That's right turn the key off then on(lights). You will hear a light click if it's working.
Yes, there is a loud click. I always thought that was the headlights coming on, LOL. Such a girl!!
Mikel1
Yeah some are louder than others. That leaves one thing left, carb cleaning.
shiftsuper175607
Hi.
I was having a similar problem.
I took a gas tank from a push mower, mounted it on a stick above the carb and let it gravity feed into the fuel pump suction. Showing me it was a fuel supply problem .The mower ran with this auxiliary fuel tank.
I disconnected the gas line before the fuel pump and put it in a bucket. I used my air gun to slightly pressure my gas tank by putting a plastic bag around the air gun and over the gas tank opening, and forced gas through to the bucket. Hooked it back up and I was good to go. Evidently gas was not flowing enough to the fuel pump.
Since it was running before you ran out of gas, I would not immediately decide it was a carb problem. The mostly likely is a fuel supply problem. The solenoid has to be opening of course as was stated. that falls into the same category.
Mikel1
She could just take off the fuel hose going to carb. Putting the hose in a gas jug or other suitable container while keeping fuel line level to the carb(minimize gravity) and cranking. If fuel flow is good then back to carb.
Get it done, babe.:wink:
