John Deere, Home Depot Special, L120 with the Briggs engine
Full tune up done last may. Plugs, filter, fuel filter, oil change will filter. Fuel treated each winter with stable, never a problem
This season the mower has developed a problem. Full tank of gas, starts right up and mowes perfectly. Get done mowing. Next time with the fuel a bit low the engine surges and will NOT stay running unless the choke stays on. If the fuel tank, under the seat, is topped off, it doed NOT do it. It starts right up, no choke, and mowes perfect.
The machine has 62.0 hours on it.
What do you guys think ? When it happes the see through fuel filter does seem a bit empty, and if I pump it with my fingers, it immediatly starts up and runs for a few minutes. Obviusly its a fuel delivery issue.
Thanks guys
-matt
Thanks guys
-matt
