john deere l120 cutting issue.
teagancarter
have a jd l120 with a 48" deck. this is an issue thats been going on but now its just bother me. whenever i mow i notice grass coming out the front of the deck. i notice it more on the middle and right blade side infront of the discharge chute. belt is on correctly and blades are resonable sharp. any suggestions.
thanx
KennyV
WELCOME to these Forums...
Late summer, Dry grass will blow all around... a lot more than heavier spring grass.
You might check that the front of your deck is slightly lower than the rear... :smile:KennyV
teagancarter
thanx for the reply. i went for a walk with the fam. this evening and someone down the street had a d105 and i was noticing that his deck was lower in the front.
thanx
