I have a 2001 (?) John Deere JS63C push mower with the castor wheels. It was $25 and I thought I could get it running on the cheap. It has the 6.5hp Intek engine (121602-0269-E1). Needed a carb, maintenance items, coil, gas tank. I think I have a flywheel issue but I can't get an answer from John Deere or Briggs and Stratton. It has two sets of magnets 180 degrees apart on flywheel but only 1 set is magnetized. Should both sets be magnetized? Can't get a spark.
