You are going to hate me after reading this post, but you won’t be the first to do so.  If you understand my post on resetting the air gap you would realize that the answer to that question was answered, as this would mean you need the proper gap on both legs of the magneto.  With your lack of knowledge of how engines work, I would not recommend cleaning the piston, valves or cylinder.  Could do more harm than good.  I’m getting frustrated as at this point I don’t think you will solve this problem because you keep jumping around as to what you should do.  This thread has covered the ignition system, fuel system and compression system, but at this point you’ve never completed diagnosing any one of those systems before jumping to another one.  That is why you are getting confused and confusing those who are trying to help you.  Troubleshooting small engines means to go in one direction and ruling it out before going another direction.  My recommendation at this point is get a new head gasket and reassemble the engine.  Then test the unit.  If it is still a no go, start by troubleshooting the ignition system unit you get spark, then go after the fuel system and finally look at the compression system.  Unless you use a step by step troubleshooting procedure you’ll never solve the problem unless you get very lucky.  Probably my last post here until I see a more direct route on your part.  Once again read my signature, as you may agree with others that I only know book knowledge and it’s time to start ignoring me. Sorry!!!
