Either the carb is loose on the intake tube or the intake tube is loose on the block... Carb might just needs to be tore apart and soaked in a carb dip change the seat also....
At first I thought it was the gov spring that was very loose in the video.. Fuel line issue.... Tank nipple clogging... Are all suspects... Fuel line is very cheap.......
Let us know Mon Ami ~!~!
Okay, I believe I have a couple feet of fuel line hanging around. I'll just replace whatever I can find for line and make sure things are tightened down. I won't be able to do it until this weekend most likely. thank you!
