PJ
- Mar 18, 2012
- 4
- 176
Ok I replaced the head gasket, put on a shut off valve, rebuild the carb, and oil the autochoke and I mowed for about an hour, stopped for a 15 minute break, same d*mn thing, I pulled five or six time and it started. When I pull it, I sounded like it was popping in the carb. And it does actually feel like it it turns over real easy when I pull it too.
You have touched on it a few times "when i pul it it turns over easely" clearly compression lost and be hard to start. There is more methods to check like removing the sparkplug squirting a spoonful of fuel/oil mixture replace the sparkplug and start it. It is clear that compression is your problem. You are mowing a large area for the mower size it will need good maintanance
Good luck
