John deere gx75, scratching my head.
Kradebaugh73
Well, I tested for spark, and I have spark. Engine gets hot and it dies. Will not start back up. Not sure if it is a strong or weak spark, but seems sufficient.
Kradebaugh73
And I have fuel. As soon as I wouldn't start back up, I opened the drain on the bowl, and it was full of fuel.
Kradebaugh73
Well turns out it's a weak spark. I let the mower cool off and tested the spark again. So it is indeed a bad coil.
I appreciate all of you guys!
Kradebaugh73
But if anyone can point me to a Chinese coil that would work, I would be greatful!
kjonxx
Amazon has the coil for 34.00
RevB
I am planning on testing it tomorrow after I get off work. But for giggles I tried to find a replacement ignition coil, to find an idea on what it's going to cost. Apparently I can get one from John Deere,
But it is expensive lol
Before you buy another coil check continuity of the spark plug lead to the cap. A lot of these are carbon track plug wires meaning they have a carbon coated string as a conductor. And the carbon is dust. Over time the dust migrates out of the crimped connectors and then no spark. Damned seldom a coil just up and "fails".
Old fiddler
I had a 12 hp Briggs that I serviced - did the same thing - hear up, die, cool off, ran - the fins in the head were packed tight with grass. Cleaned it out, problem solved
Kradebaugh73
while the engine is cool, the coil ohms at
All the service techs have said it before, but I’ll say it again. Today’s coils can not be tested unless you have $$$$$ equipment because of the Hall effect trigger inside. That means pulling out your VOM is just a waste of time.
