john deere fuel pump leak
randynma
fuel pump is leaking from what looks like a gold screen on the side replaced pump but problem still exist. model#LA115 series 100///does not do it if idleing only when throttled up thanks
reynoldston
seeing you have replaced the fuel pump the only thing I can think of checking is the vent in your gas tank or your new fuel pump is bad.
