John Deere engines?
Rickcin
Does JD actually make their own VTwin engines for their lawn tractors?
RDA.Lawns
Thats true some are. Forgot about that.
Harvis
No. They are Briggs motors
The flywheel cover will say JD, but on the side of the ones I checked out at my local Home Depot, it says B&S.
B&S has had some bad times with their intake systems in the last few years, and I suspect that JD felt that putting their name on the motor would help sales.
RDA.Lawns
JD puts their name on all engines on their mowers. In a few cases they even add their wiring harnesses to them. Fixing it to where you have to buy parts from them.
miroberts
Some are Kohler - look on the engine placard and it will tell you the make, series, model and serial number.
RDA.Lawns
John Deere dosent make their engines
