john deere d140
dedeynebill
Hi everyone. I just replaced my mower belt, but cant cut grass as the blades spin backwards. I took off the guard to double check( just for a second)
Hope someone can tell me what I did wrong.
Thanks
You probably put engine to deck section in a figure 8 pattern.
This the belt shape when routed porperly.
dedeynebill
Thanks
Thanks to everyone. You are right, problem is solved. Again Thanks
