C catman606 Member Joined Jun 20, 2021 Messages 36 Jul 21, 2021 #21 Do what I did three years ago to my old Craftsman, go to FB Marketplace and find you a $50 Flathead.
S slomo Lawn Pro Community Leader Joined Jul 14, 2019 Messages 7,217 Jul 21, 2021 #22 That Briggs manual says turn crank CCW. Is that correct? Thought it was CW looking down at the flywheel? Typo?
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,571 Location Pluto Jul 21, 2021 #23 slomo said: That Briggs manual says turn crank CCW. Is that correct? Thought it was CW looking down at the flywheel? Typo? View attachment 57585 Click to expand... Not if you are turning from the PTO which is lot easier when the shroud is in place. They assuming that the shroud is in place and you are using a wrench or pull bar to turn the engine via the PTO end. Last edited: Jul 21, 2021
